Running Vb Script
Hello,
I can run below vbs from window without any problem.
but when I use it in VG scrip, it won't work.
the job of this vbs is to delete a file in message directory.
please advise,
Set obj = CreateObject
("Scripting.FileSystemObject") 'Calls the File
System Object
obj.DeleteFile("C:\Program Files\IVR Masseging and
Recharging phone\Msgfile\$RV[LookForMsg_1_1].wav") 'Deletes the file throught the DeleteFile function
vg.Run_ResultReturn $RV_LINEID, "[fileStatus]{"& Success &"}"
set vg = Nothing
Do you have any Anti-Virus type applications on the system that would prevent the execution of VBScripts?
This is usually what is stopping VB Scripts that are started by the VoiceGuide script from running.
Hello,
I have disable my anti Virus and run the vbs in VG again, but still it is not working.
please note if the anti virus stop running the vbs, it should also stop it when I am running it from windows.
Farzad
Can you try fully uninstalling the Anti Virus software and try again?
Not necessarily.
Which anti-virus software are you using?
Hello,
I was using AVG, but I removed it to test VB Script via the VG.
unfortunatly still the VB scrip doesn't run.
Just the reminder, I have no problem runing the VB Scrip vis the Windows.
Is it possible that there is some other anti-virus type software on that system, or was there before and was not fully removed?
In all cases where we encountered this before it was a case of anti-virus software preventing execution.
Most anti-virus software prevents process-launched VBScripts form running - and many have some way of specifying exceptions to this rule.
Quickest way to resolve this is to reformat the hard disk and re-install Windows followed by installing the Dialogic drivers and VoiceGuide.
Hello,
I have attached the log file. in this file you will see how vbs script hung.
I thought this file will help you to see if there is any other problem that VG can not complete VBS process.
0105_0700_vgEngine.zip
Hello,
I have use my other VG script that has few VBS module. it seems those module are running fine throught VG.
I can not find the differences in my VB Script that one is runing fine and the other is not.
Attached is the log file with new VG script that VBS module is running fine.
please advise, what is the differences between these two log files. ( I have sent you one log file for the script that VBS module can't run, with my previous email. )
I have use my other VG script that has few VBS module. it seems those module are running fine throughout VG.
I can not find the differences in my VB Script that one is running fine and the other is not.
To debug why a VBScript module isn't fully running the VBScript specified its best to start with something like this in the VBScript module:
vg.Admin_TraceLogAdd 0, 0, "This trace was printed from VB Script"
set vg = Nothing
then gradually add your code here:
'add some of your VBScript here
set vg = Nothing
adding more Admin_TraceLogAdd calls throughout your VBScript code will let you see which lines of your code get executed and where does the VBscript gets stuck.
Please see: http://www.voiceguide.com/vghelp/source/html/com_admin_tracelogadd.htm
Thank you for your advise,
I have implemented code lines you mentioned, but still the vbs module won't execute.
please note my other vbs mode works fine, this code also works fine in windows the only problem it won't run in VG.
here is what I have added to my code:
Set obj = CreateObject("Scripting.FileSystemObject") 'Calls the File System Object
Recharging phone\Msgfile\20123502350.wav") 'Deletes the file throught the DeleteFile function
set vg = Nothingvg.Admin_TraceLogAdd 0, 0,
Please change the script that your 'VB Script' module runs to:
vg.Admin_TraceLogAdd 0, 0, "trace point vg"
vg.Admin_TraceLogAdd 0, 0, "trace point fso"
obj.DeleteFile("C:\Program Files\IVR Masseging and Recharging phone\Msgfile\20123502350.wav")
vg.Admin_TraceLogAdd 0, 0, "trace point delete"
vg.Run_ResultReturn $RV_LINEID, "[fileStatus]{Success}"
set vg = Nothing
also, I think the file to be deleted should not be hard coded, but and $RV shold be used for it, yes?
Please post vgEngine trace of the call capturing the attempt to run the above VBScript.
the code is working now. I am sure these sample vbs codes can be used for all VG user.
many thanks for your help.
