Dialogic Board - Engaged Tone
Iam using Dialogic board. My application after runnung for some time about 1 week, when I call back the board it gives engeged tone. I need to close and open my application(not pc).
I have tried to have a menu option to call sethook. But this sethook call also is in vain.
Can u pls advice how to troublehoot this.
Note: I have tried to simulate this problem but not able to simulate. The problem occurs by itself after my application runs for a week or more than that.
thanks,
Siva
Hi I found again that once the problem comes even after relaunching the application the line goes engaged very shortly. Only a reboot of my PC helos to recover from the problem
Are you using VoiceGuide or some other application?
From your problem description it sounds like you are using some other application - you should ask suppliers of that software/toolkit for help instead.
VoiceGuide does not have such problems.
