Programming
any way to have an emmulation of running program, to test off site for debugging new scripts and program script add-ons
Usual approach is to install an evaluation version of VoiceGuide in VoIP mode, and just test new scripts by placing VoIP calls into VoiceGuide system. (eg: SJPhone softphone can dial IP addresses direct, some VoIP hardphones can also dial IP direct.)
This way you are running and testing the actual software - same as used on live system, instead of running on emulator - which would just test the emulator...
