Guest Mike Report post Posted 12/17/2003 08:52 PM I would like to have a system that: a) Greets the incoming call. prompts the caller for an extension c) connects to extension d) allow the caller to record a voice mail message It will have one phone line coming in, two coming out. What do I need to do this? Thank you, -Mike Share this post Link to post
SupportTeam Report post Posted 12/17/2003 09:28 PM Will the transfers be just 'hookflash transfers', or will you want to make a call on another line and connect the two lines together? If hookflash transfers then the Professional version of VG will be OK, If you want to use "Dial-And-Conference" then you will need Pro+Dialer license. As you are doing call transfers you should use a Dialogic card (eg: D/4PCI) Share this post Link to post
