Please Help: D/300pci E1
Hi.
I really hope someone here can help me with the configuration of my Dialogic Card.
Its a D/300PCI E1 which was working with its own telephony app. Not content with that, I though I would use it to develop my own program and set about installing the latest Sofware which all seems to be working OK.
The system is a Windows 2000 machine, running the 5.1.1 DMA5 Dialogic software.
I am Using NTL E1 lines, which are running q.931.
Right, I thought. Lets configure it using the Configuration Manager..... And there I failed. I dont have a *clue* what I should be putting in all the boxes.
Is there a guide to setting these things up?
I have actually managed to start the card up, and the lights on the back go green - but I cant run any of the software. Talker32 causes a GPF, Horroscope reports : DX_SETHOOK Failed.
Please, for the love of god help a very eager, but alas, oh so stupid person!
David Riches.
Can you try some other Dialogic demo programs, eg: ANSRMT.EXE, usually found in:
C:\Program Files\Dialogic\SAMPLES\ANSWER\ANSRMT\ANSRMT.EXE
thanks for the quick response.
When running the program:
Thread 0: Error: Lasterr 0x0a1, Device = dtiB1T1
then
Exiting with error 2
Many thanks
David
First you'll need to get the Dialogic demo/test apps working...
I'd recommend contacting your local Dialogic distributor for technical assistance on configuring your card to work correctly...
Hello All... I've got the exact same error.... how did you solved this one??
Can you list your system specs and what type of lines you are using:
Windows version :
Dialogic System Release drivers version :
Dialogic card :
Protocol used on T1/E1 line :
Company which supplied the T1/E1 line :
Any 'features' enabled on these lines? :
Here it goes
Windows version : Windows 2000
Dialogic System Release drivers version : 5.1.1 SP1
Dialogic card : D/300
Protocol used on T1/E1 line : ISDN CRT4
Company which supplied the T1/E1 line : a localc company (in central america)
Any 'features' enabled on these lines? : nope
Thank you!
This was posted earliear on the Forum... makes sense... but still... you say talker 32 SHOULD work?
SupportTeam
Posted: May 18 2005, 11:10 AM
Group: Admin
Do not use Talker32 - it will not work on E1 ISDN channels.
If ISDIAG works then your Dialogic card & drivers setup is OK.
No need to install TAPI&Wave drivers - you will not use them on E1 ISDN systems.
QUOTE
We have also installed VG 6.0 fo dialogic and the VG doesn't recognize the channels
Have you set up the Config.xml file properly?
Please post your Config.xml file from VG's \data\ subdirectory.
Please post a screenshot of what you see when you start VG.
Do not use Talker32 - it will not work on ISDN channels.
ISDN lines should be tested with ISDIAG.
Have you tried using ISDIAG?
This mean that d300pci does not support TAPI at all? But it is listed in your recommanded hardware.
With D/300* and other digital cards you would use "VG for Dialogic", which does not use TAPI drivers.
"VG for Dialoigc" should be used with all Dialogic cards. Dialogic's TAPI/Wave drivers have problems.
