invoso.com Report post Posted 02/06/2013 11:19 AM Hi, typically I use ODBC to connect to database. Now I use ADO.NET to test dialer functionality, but I don't know how to use it in Database Query module. <Dialer> <OutDialQue_ADODB_Provider>Npgsql</OutDialQue_ADODB_Provider> <OutDialQue_Database>vgDb</OutDialQue_Database> <OutDialQue_ConnectString>Server=IP;User Id=user;Password=pass;Database=database;</OutDialQue_ConnectString> <OutDialQue_SqlPrefix>SELECT</OutDialQue_SqlPrefix> <OutDialQue_SqlSuffix>LIMIT 1</OutDialQue_SqlSuffix> <OutDialQue_PortToUse_LinkField></OutDialQue_PortToUse_LinkField> </Dialer> I use different IP addresses and databases and put it all in $RV[connection_string] so I need to change connection string: e.g. ODBC; Driver=PostgreSQL Unicode; Server=$RV[server]; Port=5432; Database=$RV[database];UID=user;PWD=pass; How to address ADO.NET like above? How to fill out database module to reach same result. Can You describe difference between ODBC and ADO.NET? Performance or other? Share this post Link to post
SupportTeam Report post Posted 02/07/2013 10:55 AM To connect to PostgreSQL from VoiceGuide's Database Query module you can use the Npgsql ADO.NET Data Provider. (provided here: http://voiceguide.com/forums/index.php?showtopic=9424&view=findpost&p=36136) The Connect String should be something like this: Server=myip;User Id=myuser;Password=mypass;Database=dbname; Would recommend using ADO.NET Provider before trying ODBC. NB. Setting up ODBC to Postgres is outside scope of this forum. Best to check with PostgreSQL support regarding ODBC. Share this post Link to post
