Calling Sql Server Stored Procedures
Hello,
I have Voice Guide for TAPI running on Windows XP. I have an 2012 R2 SQL Server Database.
I have tried to use SQL Statements with the database module and it succeed for simple queries however when I use some SQL Server functions like CONVERT or CASE in the statement it fails always although I tried it on the server directly and it succeed.
Also I tried to call SQL Server Stored Procedures using this text
exec sp_name
It also fails.
Kindly let me know how to solve the two problems above.
Regards,
Ehab Zaky
In VoiceGuide v5 you may need to use the 'Run VBScript' module to make the CONVERT / CASE etc. SQL queries
You would need to connect to the database from within a VBScript and run the command.
In VoiceGuide v7 you should be able to run the CONVERT / CASE / EXEC etc. commands from the Database Query module.
if you are using a Dialogic card on your system then we would recommend using VoiceGuide v7.
