Guest enadhazeem Report post Posted 03/03/2013 07:32 PM I have a Dialogic D/41 EPCI & VoiceGuide 6. I have an application that depends entirely on the ability to detect CallerID. When connected to a landline, it works fine. When connected to a GSM gateway, it does not. I then connected the GSM gateway to a CallerID-enabled desktop phone (Panasonic) It worked. The Caller's number appeared on the phone's display but won't appear in Dialogic application. When I checked with the manufacturer, I was told the GSM gateway send CallerID using FSK protocol. My question is: 1) Does Dialogic D/41EPCI support CallerID throught FSK? and if it does, how to enable this feature. Would using a higher version of VoiceGuide help solve this problems. Thanks. Share this post Link to post
SupportTeam Report post Posted 03/03/2013 08:36 PM You would need to see the data sheet for your card to see what protocols it supports. Current model D/4PCIUF supports: Analog Caller Identification Applicable standards: Telcordia TR-TSY-000030 Telcordia TR-TSY-000031 TAS T5 PSTN1 ACLIP: 1994 (Singapore) British Telecom SIN 242 (Issue 01)nt British Telecom SIN 227 (Issue 01) Japan NTT CLIP Modem standard Bell 202 or V.23, serial 1200 b/s (simplex FSK signaling) Receive sensitivity –48 dBm to –1 dBm Noise tolerance Minimum 18 dB SNR over 0 dBm to –48 dBm dynamic range for error-free performance Data formats Single Data Message (SDM) and Multiple Data Message (MDM) formats via API calls and commands Impedance 600 Ohm for D/PCIUF Matching complex impedance specified in TBR-21 for D/4PCIUF-EURO. Message formats ASCII or binary SDM, MDM message content More information can be found on D/4PCIUF data sheet: http://www.dialogic.com/~/media/products/docs/media/media-processing/8497_D4PCIUF_D4PCIU4S_ds.pdf Share this post Link to post
