Data Is Not Recorded In Db.
Hello,
some time VG doesn't record data into the access database.
Please see attached log file in MSWord. I have move the log file content into the MSWord file to highlight the related area for your quick access.
it is important for me to have data recorded into the access database. skipping the data can case major problem for my business.
thanks for your help.
If the module is ran then the SQL statement would be executed.
So most likely the script never reaches your Database module that does the insertion. (maybe caller hangs up earlier in the script etc.?)
The trace was not attached.
Please post full trace .ZIPed and just indicate at what timestamp in the trace we should be looking at.
Please post the script that you are using as well.
