sosseminarsinc Report post Posted 12/23/2003 02:53 AM I just upgraded from Windows ME to Windows 2000 Professional. Prior to Win2000, my scripts executed fairly quickly, but now I'm getting long delays before it takes action on a path. When a (wav) message is playing, if I wait until the message is finished before pressing a key, the path is taken immediately, but, if I press the key before the message stops, the sound stops, but there is a long delay before the next module is executed, almost like the script is still playing, but such that it can't be heard. When the wave file stops playing the next module executes without incident. I'm running Windows 2000 SP 4, Voiceguide 5.03. WincommV.92 modem Like I said everything seemed fine, until I upgraded to Windows 2000. Any ideas. Share this post Link to post
SupportTeam Report post Posted 12/23/2003 04:18 AM Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong. (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call.) I suspect that this modem's Win2000 drives are just not as good as the Win98 drivers - and they take longer to report that modem has completed play... Share this post Link to post
sosseminarsinc Report post Posted 12/31/2003 02:12 AM 205753.76 0 ring 1 205753.76 0 callstate ACCEPTED 65792 0 0 Here's the log you requested. I noted the first place where it could occur. I switched to Win2000 at VG recommendation, to solve a problem where the system was crashing. It doesn't appear to crash now, not I have a new problem, as described. I'm using the modem manufacturer's win2000 driver. Is that correct? Can I, or, should I use the ME driver with Win2000? 205756.90 0 tapi Reply (LineEvReply) ok 65791 0 205756.90 0 callstate CONNECTED 65792,0,0 205756.90 0 WorkingModeTAPI@Connected= 205756.91 0 WorkingModeScript@Connected= 205756.91 0 Inband detection not enabled 205756.93 0 StartLoadedVgs at 12/30/2003 8:57:56 PM 205756.95 0 [Answer&Intro] Playing 205756.96 0 [Answer&Intro] Playing (C:\VGTTS\Primarygreeting.wav) 205757.65 0 PlaySoundStart ok [C:\VGTTS\Primarygreeting.wav] 205757.66 0 RunModule PLAY end <---- starts playing my greeting 205803.13 0 dtmf 1 (65792,49,2) <-------I depress the 1 key to start recording, but while the greeting is playing 205803.16 0 LsPlayMsg 1 205857.77 0 PlaySoundStop ok <---no sound is playing, but it waits for the full length of the message, as though it were playing 205857.80 0 [PreRecordName] Playing <---starts play next message, as though nothing was wrong. 205857.80 0 [PreRecordName] Playing (C:\VGTTS\Recordcustname.wav) 205858.31 0 PlaySoundStart ok [C:\VGTTS\Recordcustname.wav] Share this post Link to post
SupportTeam Report post Posted 01/02/2004 10:23 AM Some modems have delays stopping the playing of WAV files after they are instructed to stop playing them. Looks like you have one of those modems... The problem usually lies in the modem's Windows' drivers, so it's a good idea to first check with the manufacturer if a newer version of the drivers has been released... Failing that the only option is to change to a different modem or get a Dialogic card... Can I, or, should I use the ME driver with Win2000? Not possible. Win98 drivers are written top be used under win98, and Win2000 drivers are written to be used under Win2000 - you cannot just start using a different driver - but again all modem driver related questions are best addressed to the modem manufacturer. Share this post Link to post
