Guest fsoudbakhsh Report post Posted 03/10/2013 02:37 AM Hello I have took capture screen of the problem I have with VG Script designer screen problem. Please see the attached file. Regards, VG screen problem.zip Share this post Link to post
SupportTeam Report post Posted 03/10/2013 09:22 AM It looks like you are using an "Aero Glass" theme on Windows. Can you please change the theme to be the "Windows Classic" theme? The script designer will encounter some problems when the "Aero Glass" theme is used on Windows. The latest versions of the script designer should have displayed a warning at first start time advising that the "Aero Glass" theme should not be used. Share this post Link to post
Guest fsoudbakhsh Report post Posted 03/13/2013 01:59 AM thanks, the problem solved, however the window Classic Theme is not really presentable. Share this post Link to post
