Vg Windows Screen Problme
It looks like you are using an "Aero Glass" theme on Windows.
Can you please change the theme to be the "Windows Classic" theme?
The script designer will encounter some problems when the "Aero Glass" theme is used on Windows.
The latest versions of the script designer should have displayed a warning at first start time advising that the "Aero Glass" theme should not be used.
thanks, the problem solved, however the window Classic Theme is not really presentable.
