Problem With Wav Playback
Hello,
My configuration:
1. Using Windows 2000 - SP4
2. Dialogic v5.01 & SAPI v5.0
3. VoiceGuide (Eval) - Latest downloaded from your site.
I am facing a problem - When trying to connect, the configured WAV file is not being played back, and it hangs up the call. I have attached PayGetId.wav for ur reference. It is in
PCM 11.025 kHz, 8 Bit, Mono
format, but as u can see it is not accepted by ur software.
Additionally, the WAV file has been downloaded from your site itself...
Attaching the Event Log below:
08921 6 tapie linedevstate 2048 0 0
08921 6 tapie callstate OFFERING 65623 0 4
08937 6 tapie callinfo CALLEDID
08937 6 tapie callinfo ORIGIN
08937 6 tapie ring 0
14921 6 tapie ring 2
14921 6 Answer the call
14921 6 lineAnswer(65623) => 66068
15468 6 tapie callstate CONNECTED 65623,1,0
15468 6 WorkingModeTAPI=
15468 6 WorkingModeScript=
15515 6 Inband detection not enabled
15515 6 tapi  Reply 66068 0
15515 6 [Get Client ID] Number Input
15515 6 [Get Client ID] Playing (PayGetId.wav)
15515 6 Play Start line[6] err=[0 wavec waveOutOpen(0x0, 0x0, 0x2a45240, 0x0, 0x0, 0x5) => 32 (WAVERR_BADFORMAT) - format query with wave mapped] file[PayGetId.wav]
15515 6 PlaySoundStart line[6] err=[0 wavec waveOutOpen(0x0, 0x0, 0x2a45240, 0x0, 0x0, 0x5) => 32 (WAVERR_BADFORMAT) - format query with wave mapped] [C:\Program Files\ivg\system\voicedlgc\ErrorPlayingFile.wav]
15515 6 For Dialogic use: PCM 11Khz 8bit Mono
15515 6 HangupCall called from [srlib 609]
15515 6 Hanging up call...
15515 6 PlaySoundStop ok
15531 6 fnHangupCall end
17500 6 tapie linedevstate 2048 0 0
17500 6 tapie callstate IDLE 65623 0 0
17500 6 WorkingMode@Idle=
17515 6 set EV_TIMEOUT_TIMETOREINITLINE 2
17515 6 tapi  Reply 65913 0
18531 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
18531 6 ReinitTelephony due to IDLE start
18531 6 tapic lineDeallocateCall(MainCall:65623) 0
18687 6 lineOpen(6) => 0
18687 6 Waiting for a call...
18687 6 lineOpen(6)LineHandle=66050
Pls clarify on priority. Awaiting a solution...
Rgds,
Sudhi
PayGetId.zip
Sounds like the cards Wave drivers were not correctly installed - can you
try removing all the wave drives on your system (including any sound card drivers) and then re-installing the wave drivers for your telephony device first. Try calling in after doing this, and if the sound can be heard over the phone you can then try to re-install your sound card drivers.
