Spliting Channels Licenses For Two E1 Trunks
Is possible to split licenses so that active will ports 1-15 in first E1 trunk and 31-45 on second trunk?
I need to dialing out with different E1 then incoming calls.
Yes. You can specify which specific ports to open. The ports to open are specified in the Config.xml file.
You would need to ensure that incoming calls only arrive on the ports that you have 'opened' in the Config.xml file.
Note that we recommend that calls are presented on ISDN trunks in a 'round robin'/'circular' order to allow calls being evenly distributed across all available channels. Opening only some of the channels on an ISDN trunk that can carry more simultaneous calls then the number of opened channels would result in some calls from being answered (the calls that arrive on unopened channels would not get answered)
