Dan Clements Report post Posted 08/27/2005 06:14 AM Can anyone tell me what is happening here? I am trying to trasfer a call, detect if no answer, or busy and then move on to another line. VG dials the ext ok and rings it for 3 to 4 rings about 10 to 13 sec's then it hangs up?? Thanks Dan Clements 140656.23 1 timer clear 140656.27 1 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER 140656.68 1 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 140656.68 1 event EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901 140656.68 1 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,, 140656.70 1 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found 140656.70 1 timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime (30 sec) 140656.70 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 140656.70 1 state [Call Front Desk] Monitored Hookflash Transfer to ,201 140657.45 1 tw PlayEnd 1 0 140657.45 1 play end id=0, (current ID) 140657.45 1 event EV_PLAY_FINISHED, code=8001, state=1902 140657.45 1 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,, 140657.46 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,, 140657.46 1 event TDX_DIAL, code=132, state=1902 140657.46 1 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,, 140657.50 1 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec 140657.50 1 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter 140659.42 1 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter 140659.42 1 event EV_TIMEOUT_Transfer_Prefix_PauseAfter, code=9030, state=1902 140659.42 1 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,, 140659.43 1 Dial(,201, cp on) call 140659.43 1 Dial(,201) ok 140659.44 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 140704.34 1 tw DialogicEvent 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1, 140704.34 1 event RINGBACK, code=134, state=1903 140704.34 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,RINGBACK,199,0,0,DE_TONEON,TID_RNGBK1, 140704.34 1 event TID_RNGBK1, code=134, state=1903 140704.36 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,TID_RNGBK1,199,0,0,DE_TONEON,TID_RNGBK1, 140704.36 1 event TDX_CST, code=134, state=1903 140704.36 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1, 140707.40 1 tw DialogicEvent 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1, 140707.40 1 event RINGBACK, code=134, state=1903 140707.41 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,RINGBACK,199,0,0,DE_TONEON,TID_RNGBK1, 140707.41 1 event TID_RNGBK1, code=134, state=1903 140707.41 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,TID_RNGBK1,199,0,0,DE_TONEON,TID_RNGBK1, 140707.42 1 event TDX_CST, code=134, state=1903 140707.42 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1, 140708.47 1 tw DialogicEvent 133,TDX_CALLP,10,1,0,TDX_CALLP,CR_CNCT,CON_CAD 140708.48 1 event CADENCE, code=133, state=1903 140708.48 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CADENCE,10,1,0,CR_CNCT,CON_CAD, 140708.48 1 event CONNECT, code=133, state=1903 140708.49 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CONNECT,10,1,0,CR_CNCT,CON_CAD, 140708.49 1 event CON_CAD, code=133, state=1903 140708.50 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CON_CAD,10,1,0,CR_CNCT,CON_CAD, 140708.50 1 event CR_CNCT, code=133, state=1903 140708.50 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CR_CNCT,10,1,0,CR_CNCT,CON_CAD, 140708.51 1 event TDX_CALLP, code=133, state=1903 140708.51 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,TDX_CALLP,10,1,0,CR_CNCT,CON_CAD, 140708.52 1 LsXfer_3 CR_CNCT on an XT_HOOK_MONITORED 140708.54 1 xfer dial 140708.57 1 tw PlayEnd 1 0 140708.57 1 play end id=0, (current ID) 140708.57 1 event EV_PLAY_FINISHED, code=8001, state=1905 140708.58 1 LsXfer_5A : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,, 140708.58 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,, 140708.59 1 event TDX_DIAL, code=132, state=1905 140708.59 1 LsXfer_5A : 132(EV_UNKNOWN_132),TDX_DIAL,0,0,0,,, 140708.60 1 sXferDialResult_SuccOrFail= 140708.61 1 rv add [Hangup Time]{8/25/2005 2:07:08 PM} 140708.61 1 state Hanging up call... [LsXfer_5A] 140708.62 1 HangupCall_Common hCall=1 140708.63 1 rec RecSoundStop ok 140708.64 1 play PlaySoundStop ok 140708.64 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 140708.64 1 fnHangupCall end 140708.69 1 event callstate IDLE 1 0 0 140708.70 1 WorkingMode@Idle= 140708.70 1 timer clear 140708.71 1 rec RecSoundStop ok 140708.72 1 play PlaySoundStop ok 140708.73 1 rv add [CallEndTime]{8/25/2005 2:07:08 PM} 140708.84 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 140708.84 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 140708.85 1 event TDX_SETHOOK, code=135, state=900 140708.85 1 LsAwaitingCalls EV_UNKNOWN_135 140709.76 1 timer fired EV_TIMEOUT_TIMETOREINITLINE 140709.76 1 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900 140709.77 1 init atidle reinit : start 140709.77 1 init atidle reinit iConferenceOtherLegLid=-1 140709.77 1 init atidle reinit : reset all LineState variables 140709.78 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 140709.78 1 state Waiting for a call... 140710.08 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 140710.08 1 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900 140718.18 0 sys cleanup Start 140718.25 0 sys cleanup End Share this post Link to post
SupportTeam Report post Posted 08/27/2005 06:58 AM What does the ringback sound like when the destination extension is ringing? Have you set the ringback sound definition to match in the ConfigLine.xml file? Can you please record the ringback sound, .zip it up and post here. Share this post Link to post
Dan Clements Report post Posted 08/27/2005 02:02 PM Awesome reply times!!!Over all your tech support is 2nd to none! The attached Zip file is my ConfigLine file, the ringback, and a busy tone from my PBX, KCE FX416. The ring back is quick and only one tone, as VG hangs up right after it is issued. I have downloaded Audacity, but am not sure how to read it all. Maybe a few pointers on how to determine the essentials will help as I am sure I'll have issues with the other tones needed. The Attached ConfigLine file has only been modified to what I could decipher the busy tone to be. The may give you some idea of what I am thinking when I use Audacity. I use the plot spectrum tool to read the Hz of the largest energy peak. I am not sure if this is the way to do so. I also don't know how to determine deviation or a 2nd frequency tone, or how to measure the time off and on. Dan Share this post Link to post
Dan Clements Report post Posted 08/27/2005 02:34 PM Zip attached Tones_and_ConfigLine.zip Share this post Link to post
Dan Clements Report post Posted 08/28/2005 05:16 AM Ok I got a better copy of a ringback tone, and saw someother post on how to use Audacity and came up with a 400Hz ring tone with 1 sec on and 2 off. I set my Configline tinback tones to 400 both freq's, dev 50, on time 100 dev 40, off time 200 dev 40. Now I get a call trasfer of 3 rings before the call is hung up. Attached is the new trace log and the better ringback file. Thansk for any help you can give: Dan 130516.12 1 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,, 130516.12 1 Dial(,201, cp on) call 130516.13 1 Dial(,201) ok 130516.13 1 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 130521.02 1 tw DialogicEvent 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1, 130521.02 1 event RINGBACK, code=134, state=1903 130521.03 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,RINGBACK,199,0,0,DE_TONEON,TID_RNGBK1, 130521.03 1 event TID_RNGBK1, code=134, state=1903 130521.04 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,TID_RNGBK1,199,0,0,DE_TONEON,TID_RNGBK1, 130521.04 1 event TDX_CST, code=134, state=1903 130521.04 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1, 130524.10 1 tw DialogicEvent 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1, 130524.10 1 event RINGBACK, code=134, state=1903 130524.11 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,RINGBACK,199,0,0,DE_TONEON,TID_RNGBK1, 130524.11 1 event TID_RNGBK1, code=134, state=1903 130524.11 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,TID_RNGBK1,199,0,0,DE_TONEON,TID_RNGBK1, 130524.12 1 event TDX_CST, code=134, state=1903 130524.12 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1, 130525.19 1 tw DialogicEvent 133,TDX_CALLP,10,1,0,TDX_CALLP,CR_CNCT,CON_CAD 130525.19 1 event CADENCE, code=133, state=1903 130525.20 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CADENCE,10,1,0,CR_CNCT,CON_CAD, 130525.20 1 event CONNECT, code=133, state=1903 130525.20 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CONNECT,10,1,0,CR_CNCT,CON_CAD, 130525.21 1 event CON_CAD, code=133, state=1903 130525.21 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CON_CAD,10,1,0,CR_CNCT,CON_CAD, 130525.21 1 event CR_CNCT, code=133, state=1903 130525.22 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,CR_CNCT,10,1,0,CR_CNCT,CON_CAD, 130525.22 1 event TDX_CALLP, code=133, state=1903 130525.23 1 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,TDX_CALLP,10,1,0,CR_CNCT,CON_CAD, 130525.23 1 LsXfer_3 CR_CNCT on an XT_HOOK_MONITORED 130525.23 1 xfer dial 130525.27 1 tw PlayEnd 1 0 130525.27 1 play end id=0, (current ID) 130525.28 1 event EV_PLAY_FINISHED, code=8001, state=1905 130525.28 1 LsXfer_5A : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,, 130525.28 1 tw DialogicEvent 132,TDX_DIAL,0,0,0,,, 130525.29 1 event TDX_DIAL, code=132, state=1905 130525.29 1 LsXfer_5A : 132(EV_UNKNOWN_132),TDX_DIAL,0,0,0,,, 130525.30 1 sXferDialResult_SuccOrFail= 130525.30 1 rv add [Hangup Time]{8/26/2005 1:05:25 PM} 130525.30 1 state Hanging up call... [LsXfer_5A] 130525.31 1 HangupCall_Common hCall=1 130525.32 1 rec RecSoundStop ok 130525.33 1 play PlaySoundStop ok 130525.33 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 130525.33 1 fnHangupCall end 130525.38 1 event callstate IDLE 1 0 0 130525.39 1 WorkingMode@Idle= 130525.39 1 timer clear 130525.40 1 rec RecSoundStop ok 130525.41 1 play PlaySoundStop ok 130525.42 1 rv add [CallEndTime]{8/26/2005 1:05:25 PM} 130525.52 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 130525.52 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 130525.52 1 event TDX_SETHOOK, code=135, state=900 130525.52 1 LsAwaitingCalls EV_UNKNOWN_135 130526.43 1 timer fired EV_TIMEOUT_TIMETOREINITLINE 130526.45 1 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900 130526.45 1 init atidle reinit : start 130526.45 1 init atidle reinit iConferenceOtherLegLid=-1 130526.45 1 init atidle reinit : reset all LineState variables 130526.45 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 130526.46 1 state Waiting for a call... 130526.77 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 130526.77 1 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900 ringback.zip Share this post Link to post
Dan Clements Report post Posted 08/29/2005 03:13 PM Did someone see this post? I noticed answers to post on the 28th and 29th after this one? Share this post Link to post
SupportTeam Report post Posted 08/30/2005 12:25 PM Still looking into this one... Share this post Link to post
ktruk Report post Posted 09/07/2005 09:15 PM Dan, I got the same answer months ago and am still waiting for some sort of answer :-( see: http://voiceguide.com/forums/index.php?showtopic=3051 Reluctantly, I have reverted back to the TAPI (Standard VG) product as I was unable to get a working solution here, which is both frustrating and disappointing. Share this post Link to post
Dan Clements Report post Posted 09/12/2005 06:38 PM Has this thread been closed? I have had no response? Please let me know if this issue can be solved or not. Thanks Dan Share this post Link to post
SupportTeam Report post Posted 09/14/2005 06:16 AM This one has posed us a bit of a problem. We have had a few users report persistent problems with "Vg for Dialogic" with false connection reports on outgoing calls and transfers when the destination phone was still ringing or was busy. Most often the ringback and busy tones was just not set right, so the Dialogic card reported that the call must be connected as it has not heard the ringback or busy tone at all. Looking at the sound files and ConfigLine.xml attached earlier in this thread we can see that the busy tone (TID_BUSY1) appears to be set right in ConfigLine.xml, but the Ringback recording does not match the TID_RNGBK1 setting in the ConfigLine.xml You mention that the TAPI version of VG is working OK, which is taken to mean that on outgoing calls when the destination phone is just ringing you do not get 'false connections reported. Please confirm that that's the case. In the latest version of VG for Dialogic (v6.0.2214) we have changed the way that call progress detection is initialized with the Dialogic card - and it does look like this has fixed the problem for another client. Please update to that latest version and then try test calls with ConfigLine.xml file's entry for TID_RNGBK1 set to : <Tone Name="Call Progress Tone TID_RNGBK1"> <Notes>The Double ringback</Notes> <ID>TID_RNGBK1</ID> <Freq1>390</Freq1> <Freq1Dev>50</Freq1Dev> <Freq2>0</Freq2> <Freq2Dev>0</Freq2Dev> <On>80</On> <OnDev>60</OnDev> <Off>200</Off> <OffDev>100</OffDev> <Count>1</Count> </Tone> as well as to the default value: <Tone Name="Call Progress Tone TID_RNGBK1"> <Notes>Ringback 1 Default Setting</Notes> <ID>TID_RNGBK1</ID> <Freq1>438</Freq1> <Freq1Dev>138</Freq1Dev> <Freq2>0</Freq2> <Freq2Dev>0</Freq2Dev> <On>130</On> <OnDev>105</OnDev> <Off>400</Off> <OffDev>200</OffDev> <Count>1</Count> </Tone> Please let us know what outcomes you get on your system and post traces from this latest version if you still have problems. Share this post Link to post
Dan Clements Report post Posted 03/29/2006 08:24 PM After several months off, I am back revisiting this issue. I have now upgraded to V 6.0.3095 Pro 4 Line. I Have NOANSWER, CONNECT, and BUSY PATHS defined. I have set ringback both ways as suggested, This is the event log with Configline.XML useing the 390 Freq1 option. I get same results with it set at default. The call just hangs up (no timeout or fail defined), as if VG in not detecting a no answer. Thanks Dan 151415.41 4 tw dtmf 1 (4,49,49) 151415.41 4 event 1, iCode=49 state=1100 151415.42 4 LsPlayMsg 1,1 151415.42 4 next module is [Live trasfer] (idx=17) 151415.46 4 play PlayStop ok 151415.46 4 rv add [Open]{1} 151415.46 4 fn RunModule start [Transfer Call,[Live trasfer],17,,] 151415.48 4 timer clear 151415.49 4 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER 151415.49 4 tw PlayEnd 4 359157 151415.49 4 play end id=359157, (current ID) 151415.50 4 event EV_PLAY_FINISHED, iCode=8001 state=1901 151415.52 4 LsXfer_1_Start : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,, 151415.52 4 path {EV_PLAY_FINISHED} not found 151415.52 4 tw DialogicEvent 129,TDX_PLAY,359157,0,0,,, 151415.52 4 event TDX_PLAY, iCode=129 state=1901 151415.53 4 LsXfer_1_Start : 129(EV_UNKNOWN_129),TDX_PLAY,359157,0,0,,, 151415.53 4 path {TDX_PLAY} not found 151415.83 4 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 151415.83 4 event EV_TIMEOUT_READYTOBEGINTRANSFER, iCode=9012 state=1901 151415.84 4 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,, 151415.84 4 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found 151415.84 4 timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime (30 sec) 151415.84 4 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 151415.85 4 state [Live trasfer] Monitored Hookflash Transfer to ,201 151416.35 4 tw DialogicEvent 132,TDX_DIAL,0,0,0,,, 151416.35 4 event TDX_DIAL, iCode=132 state=1902 151416.36 4 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,, 151416.38 4 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec 151416.39 4 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter 151416.39 4 tw PlayEnd 4 0 151416.39 4 play end id=0, (current ID) 151416.40 4 event EV_PLAY_FINISHED, iCode=8001 state=1902 151416.40 4 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,, 151418.30 4 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter 151418.30 4 event EV_TIMEOUT_Transfer_Prefix_PauseAfter, iCode=9030 state=1902 151418.30 4 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,, 151418.32 4 Dial(,201, cp on) call 151418.71 4 Dial(,201) ok 151418.71 4 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 151448.82 4 timer fired EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 151448.82 4 event EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG, iCode=9021 state=1903 151448.83 4 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 9021,EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG,0,0,0,,, 151448.83 4 Transfer timed out 151448.83 4 xfer dial ! 151449.36 4 tw DialogicEvent 132,TDX_DIAL,0,0,0,,, 151449.36 4 event TDX_DIAL, iCode=132 state=1906 151449.37 4 LsXfer_5B : 132(EV_UNKNOWN_132),TDX_DIAL,0,0,0,,, 151449.37 4 sXferDialResult_SuccOrFail= 151449.38 4 XferGoDownSpecifiedPath iXferModule_PathsToTake_Max=3 (1)=timeout (2)= (3)= 151449.38 4 path 'timeout' not found 151449.38 4 False path not defined - hangup call (iXferType=12) 151449.38 4 timer set 1 EV_TIMEOUT_HANGUP 151449.39 4 tw PlayEnd 4 0 151449.39 4 play end id=0, (current ID) 151449.39 4 event EV_PLAY_FINISHED, iCode=8001 state=1906 151449.40 4 LsXfer_5B : 8001(EV_PLAY_FINISHED),EV_PLAY_FINISHED,0,0,0,,, 151450.35 4 timer fired EV_TIMEOUT_HANGUP 151450.35 4 event EV_TIMEOUT_HANGUP, iCode=9001 state=1906 151450.36 4 LsXfer_5B : 9001(EV_TIMEOUT_HANGUP),EV_TIMEOUT_HANGUP,0,0,0,,, 151450.36 4 HangupCall start (Default Handler 60: 9001) 151450.36 4 rv add [Hangup Time]{3/29/2006 3:14:50 PM} 151450.37 4 state Hanging up call... [Default Handler 60: 9001] 151450.37 4 HangupCall_Common hCall=4 151450.38 4 rec RecSoundStop ok 151450.39 4 play PlayStop ok 151450.39 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 151450.39 4 fnHangupCall end 151450.45 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 151450.46 4 event TDX_SETHOOK, iCode=135 state=900 151450.46 4 LsAwaitingCalls EV_UNKNOWN_135 151450.47 4 event callstate IDLE 4 1,0,0 151450.47 4 WorkingMode@Idle= 151450.47 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 151450.48 4 timer clear 151450.49 4 rec RecSoundStop ok 151450.49 4 play PlayStop ok 151450.49 4 rv add [CallEndTime]{3/29/2006 3:14:50 PM} 151450.65 4 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 151451.56 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 151451.56 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 151451.57 4 init atidle reinit : start 151451.57 4 init atidle reinit iConferenceOtherLegLid=-1 151451.57 4 init atidle reinit : reset all LineState variables 151451.58 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 151451.58 4 state Waiting for a call... 151453.60 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 151453.60 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 Share this post Link to post
Dan Clements Report post Posted 03/29/2006 08:37 PM Of the three paths, Busy works. Connect hangs up the call, but dosn't take the CONNECT path, and NOASWER is as above. Thanks Dan Share this post Link to post
SupportTeam Report post Posted 03/29/2006 11:20 PM Trace shows that the Monitored transfer timed out awaiting for an answer. The system is looking for a "timeout" path in this situation, and as neither the timeout path or a 'fail' path was not defined then the call is ended. 151449.38 4 path 'timeout' not found 151449.38 4 False path not defined - hangup call (iXferType=12) When posting traces/scripts please .ZIP them up and post them as attachments. Share this post Link to post
Dan Clements Report post Posted 03/29/2006 11:38 PM Will do. I do understand VG is looking for a time out or fail However, I have a NOANSWER path defined. How is a Noanswer recognized or different form a time out? For the meantime I have set fail path so that the script will run. Share this post Link to post
SupportTeam Report post Posted 03/29/2006 11:50 PM NOANSWER is returned by Dialogic after about 60 (or 90?) seconds. On this system a timeout occurs beforehand - the timeout is set in VG .INI file in this case: 151415.84 4 timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime (30 sec) 151415.84 4 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG Change the timeout in VG.INI to say 120 seconds and you should see the NOANSWER from Dialogic call progress monitor after 60 or 90 seconds. Share this post Link to post
