Setting Tapi Control In The Vg.ini
Hi there.
I wish to set "TAPI" function calls in the VG.INI so that TAPI functions are used to request line transfers to a TAPI compatible driver.
I have set the Vg.INI params:
;"TAPI"    : TAPI functions calls are made to driver to action transfers and conferences.
;"Generate" : exlilicit tones and signals are generated using TAPI calls
;"AT"      : modem AT commands are used
TransferControl_Modem=TAPI
TransferControl_TelBoards=TAPI
...but the transfer fails and the VG debug log still shows the transfer method as "Generate" and a couple of errors.
133812.25  10 timer clear
133812.26  10 timer set 0.4  EV_TIMEOUT_READYTOBEGINTRANSFER
133812.58  10 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
133812.58  10 ScriptEventCode 9012 iLineState=1900
133812.58  10 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
133812.58  10 timer set 5  EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
133812.58  10 [TransferCall] Blind Transfer to 30 (Generate)
133812.59  10 tapic lineGenerateDigits(66235 [!] 100) => -2147483576:LINEERR_OPERATIONFAILED [80000048]
133812.59  10 rv    lg add [Hangup Time]{29/11/2005 13:38:12}
133812.59  10 Hanging up call... [lineGenerateDigits ret=-2147483576]
133812.59  10 RecSoundStop ok
133812.59  10 PlaySoundStop err=0
133812.60  10 timer set 2  EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
133812.61  10 fnHangupCall end
133812.97  10 tapi  Reply (LineEvReply) ok 66184 0
133812.97  10 callstate IDLE 66235 0 0
133812.98  10 WorkingMode@Idle=
133812.99  10 timer clear
133813.00  10 timer set 1  EV_TIMEOUT_TIMETOREINITLINE
133813.00  10 linedevstate 2048 0 0
133813.01  10 linedevstate 1 0 0
133813.91  10 timer fired EV_TIMEOUT_TIMETOREINITLINE
133813.91  10 ScriptEventCode 9008 iLineState=900
133813.92  10 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
133813.92  10      ReinitTelephony due to IDLE
133813.93  10 tapic lineDeallocateCall(MainCall:66235) 0
133813.95  10 lineOpen(10)=>
133813.95  10 Waiting for a call...
133813.96  10 LineHandle=66167
133813.97  10 amchk set AMdet=False in Reinit@idle
133813.98  10 timer set 3  EV_TIMEOUT_ATERIDLE_ALLOWOUT
133814.95  0 dial  start any summary:|10:rdy=0|11:idx=0|
133816.98  10 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
133816.98  10 ScriptEventCode 9013 iLineState=900
133818.33  0 dial  start any summary:|10:idx=0|11:idx=0|
I have tried restarting the machine and VG and such-like, but the transfer method indicated in the debug log still shows "Generate".
I am using v5.2.5003.
Can you please help.
Thanks.
PS: Any news on this thread? http://voiceguide.com/forums/index.php?showtopic=3409
Is the abve information enough to see whats going on here or do you need anything else?
If I can force VoiceGuide to use TAPI for call transfers then I am sure that my problems will be solved!
Thank you.
Looks like the TAPI driver for the device which you are using returned an error when the TAPI function was called to generate a hookflash.
As to why it gave an error you can only really ask that question from the TAPI driver provider...
No, I think you have missed the point: I don't want to "generate" a hook-flash, as I am trying to make a TAPI request to transfer a call (I'm using a BRI ISDN board). To do this, I want to set VG to work in TAPI mode, by making the setting quoted above for VG to use TAPI. Since the log shows a "generate" call being made it appears that VG (thats your product) is not making the call in TAPI mode.
I know its being ignored - because if I install ComISDN, then VG appears to switch to a TAPI mode AND CALL TRANSFERS WORK, but when trying to make a call transfer without ComISDN to a TAPI driver, the call transfer fails as listed above.
I know the TAPI driver works because I have tried it with other TAPI compatible systems which do a call transfer. Therefore, VG is not working in TAPI mode and not doing the call transfer using TAPI mode!
Attached is a zip file containing 2 sets of debug logging files. The one set marked as "VG-Gen1" show the call transfer failing as per my original post. The second set marked "Vg-Tap1" shows VG operating in TAPI mode and successfully making the call transfer. The logs were generated by starting VG, making one call, attempting a call-transfer, and hanging up, then stopping VG. The script is also included.
Highlighted below is the section showing a VG working in TAPI mode:
112519.71  8 timer clear
112519.71  8 timer set 0.4  EV_TIMEOUT_READYTOBEGINTRANSFER
112520.04  8 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
112520.04  8 ScriptEventCode 9012 iLineState=1900
112520.04  8 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
112520.04  8 timer set 5  EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
112520.04  8 [TransferCall] Blind Transfer to 30 (TAPI)
112520.04  8 lineBlindTransfer(66406,30,0) in LsXferStart => 66372
112520.21  8 callstate ONHOLD 66406 0 0
112520.53  8 callinfo DEVSPECIFIC
112520.54  8 callstate DISCONNECTED 66406 1 0
112520.54  8 ScriptEventCode 9250 iLineState=1900
112520.54  8 LsXferStart EV_REMOTEPARTY_DISCONNECT
112520.54  8 rv    lg add [Hangup Time]{30/11/2005 11:25:20}
112520.54  8 Hanging up call...
112520.54  8 RecSoundStop ok
112520.54  8 PlaySoundStop err=0
112520.54  8 timer set 2  EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
112520.55  8 fnHangupCall end
112520.56  8 tapi  Reply (LineEvReply) ok 66355 0
112520.65  8 callstate IDLE 66406 0 0
112520.65  8 WorkingMode@Idle=
112520.66  8 timer clear
112520.68  8 timer set 1  EV_TIMEOUT_TIMETOREINITLINE
112521.65  8 timer fired EV_TIMEOUT_TIMETOREINITLINE
112521.65  8 ScriptEventCode 9008 iLineState=900
112521.65  8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
112521.65  8      ReinitTelephony due to IDLE
112521.65  8 tapic lineDeallocateCall(MainCall:66406) 0
112521.67  8 lineOpen(8)=>
112521.67  8 Waiting for a call...
112521.67  8 LineHandle=66338
112521.67  8 amchk set AMdet=False in Reinit@idle
112521.67  8 timer set 3  EV_TIMEOUT_ATERIDLE_ALLOWOUT
112522.17  0 dial  start any summary:|8:rdy=0|9:idx=0|
112524.67  8 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
112524.67  8 ScriptEventCode 9013 iLineState=900
112525.19  0 dial  start any summary:|8:idx=0|9:idx=0|
Also noted in the startup process:
112354.12  0      ------------------------------------------------------------------------------
112354.12  0      VoiceGuide TAPI v5.2.5003
112354.88  0      ApiMode=[TAPI]
If I inspect the two log files together, then there are two main differences:
1. When ComISDN is used, when VG starts/initialises it sets a "Provider Type" which is set to "PROVTYPE_ComISDN" and the system appears to work in TAPI mode. However when ComISDN is not used, no Provider Type is set.
2. When ComISDN is NOT used, some "LineDevState" variables are listed in the debug list.
To wrap up: I am getting really frustrated with this and your support is not meeting my needs. I am months behind on my VG project and I am feeling really let down at the moment. Clearly, I have an issue with VG and would like you to deal with these specific points.
ktruk.zip
A note to other readers of this thread:
A working soultion was found using an Eicon card with slight modifications to VG.
In recieved email ktruk wrote:
Thank you so much for the VG.EXE update (v5.2.5015) - YES - it works!!
I will do more testing during the course of the day. If I find anything
unusual, I will let you know.
This fix will enable a range of Eicon ISDN cards (BRI & PRI) to work with
VG without ComISDN.
Although only v2 cards are "officially supported" my testing shows that V1
cards work too, but you have to copy over the v7.x Diva Wave driver to the
v6.x installation.
(copy divawave.drv to windows\system32).
The problem with ComISDN (both their dialogic & capi versions) is that
they do not work with Hunt-groups very well. The problem is that if a line
is hunted to, and found busy, but then becomes free before a new line has
answered (ie: during the hunt), the call connects to a free line, but the
DSP/wave driver connects to the previously busy channel and nothing can be
heard on the connected line. The Eicon drivers do not suffer from this,
any free line will answer any call at any time. The comISDN system will
only properley answer in strict channel sequence, which cannot be truly
enforced.
Here is the debug trace, in case it is any use to you...
111858.86  14 timer clear
111858.87  14 timer set 0.4  EV_TIMEOUT_READYTOBEGINTRANSFER
111859.26  14 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
111859.26  14 ScriptEventCode 9012 iLineState=1900
111859.27  14 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
111859.28  14 timer set 5
>>111859.29  14 state [TransferCall] Blind Transfer to 30 (TAPI)
>>111859.30  14 lineBlindTransfer(65706,30,0) in LsXferStart => 65672
111859.47  14 devstate NUMCALLS 0 0
111859.48  14 devstate OTHER 0 0
111900.35  14 tapi  callstate start
111900.36  14 tapi  callstate DISCONNECTED 65706 1 0
111900.36  14 ScriptEventCode 9250 iLineState=1900
111900.37  14 LsXferStart EV_REMOTEPARTY_DISCONNECT
111900.38  14 rv    lg add [Hangup Time]{06/12/2005 11:19:00}
111900.39  14 state Hanging up call...
111900.40  14 RecSoundStop ok
111900.41  14 PlaySoundStop err=0
111900.42  14 timer set 2  EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
111900.43  14 fnHangupCall end
111900.44  14 devstate NUMCALLS 0 0
111900.45  14 devstate OTHER 0 0
111900.46  14 tapi  callstate start
111900.47  14 tapi  callstate IDLE 65706 0 0
111900.48  14 WorkingMode@Idle=
111900.48  14 timer clear
111900.49  14 timer set 1  EV_TIMEOUT_TIMETOREINITLINE
