Compare Userpin
I will like to know if evaluate expression will work with Access Database query result? example is: "$RV[GetUserRecord_2_1]"="$RV[AskUserPIN]"
I am trying to verify that the PIN Code entered by a user is the same as the Pin code already retrieve from the Database. Is "$RV[GetUserRecord_2_1]"="$RV[AskUserPIN]" correct?
Plz reply
regards
Yes, it will. You can use any Result Variable in the Evaluate Expression module.
What you describe is a basic PIN check against a database which is a very common thing in many scripts that need to check the PIN.
You've already posted a similar question yesterday here: http://voiceguide.com/forums/index.php?showtopic=3849
If you are having problems I'd suggest you follow instructions given by us in that post...
