Guest Jack_VR Report post Posted 07/05/2005 01:41 PM Hi, The message playing was stopped by VG 4 Dialogic patch system, Why? Here is the log of that call, FYI. 092310.54 2 state Dialing 4167237597 092311.11 2 LsWaitAfterDialingOut : 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND, 092311.14 2 LsWaitAfterDialingOut : 134,TDX_CST,1537,0,0,DE_LCON,, 092322.97 2 LsWaitAfterDialingOut : 133,VOICE,10,3,0,CR_CNCT,CON_PVD, 092322.99 2 LsWaitAfterDialingOut : 133,CONNECT,10,3,0,CR_CNCT,CON_PVD, 092322.99 2 LsWaitAfterDialingOut : 133,CON_PVD,10,3,0,CR_CNCT,CON_PVD, 092323.00 2 LsWaitAfterDialingOut : 133,CR_CNCT,10,3,0,CON_PVD,, 092323.02 2 LsWaitAfterDialingOut : 133,TDX_CALLP,10,3,0,CR_CNCT,CON_PVD, 092323.02 2 state live person answered. start [C:\Program Files\VoiceGuide\Scripts\CallOut_am.vgp] 092323.04 2 FindFullPathToScript_VgsOrVgp start [C:\Program Files\VoiceGuide\Scripts\CallOut_am.vgp] 092323.05 2 FindFullPathToScript_VgsOrVgp 1 092323.19 2 loaded [C:\Program Files\VoiceGuide\Scripts\CallOut_am.vgp] into:9 092323.24 2 state [intro msg] Playing 092323.25 2 state [intro msg] Playing (2k50629audios\3 prompts and short message 49 toll free 8 mhz.wav) 092431.22 2 LsPlayMsg EV_UNKNOWN_134,BUSY 092431.24 2 state Hanging up call... 092431.32 2 rec RecSoundStop ok 092431.33 2 play PlaySoundStop ok 092431.33 2 fnHangupCall end 092431.35 2 LsAwaitingCalls EV_UNKNOWN_134 092431.35 2 LsAwaitingCalls EV_UNKNOWN_134 092431.47 2 play end id=442078, (current ID) 092431.49 2 LsAwaitingCalls EV_PLAY_FINISHED 092431.49 2 LsAwaitingCalls EV_UNKNOWN_129 092431.52 2 WorkingMode@Idle= 092431.52 2 rec RecSoundStop ok 092431.54 2 play PlaySoundStop ok 092431.55 2 After Hangup script:[C:\Program Files\VoiceGuide\Scripts\erase_number_am.vgs] 092431.57 2 FindFullPathToScript_VgsOrVgp start [C:\Program Files\VoiceGuide\Scripts\erase_number_am.vgs] 092431.57 2 FindFullPathToScript_VgsOrVgp 1 092431.58 0 LoadedVgs_Find C:\Program Files\VoiceGuide\Scripts\erase_number_am.vgs at idx=8 092431.60 2 state [erase number] Running VB Script... 092431.60 2 rv replace start (strlen>500) 092431.80 2 Run Script waiting. iRunWait=1 (shellid=128, process=1544) 092432.79 2 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE 092432.79 2 task completed (shellid=128, process=1544) vgm=110, iRunWait=1, iRunWait_ExeResult_NextVgm=0 092432.80 2 no result file returned from program (VGRUNRESULT_2.TXT or SHLRESLT.TXT) 092432.80 2 task completed LsRunWaitChooseNext iNextVgm=112 092432.85 2 state [call length] Running VB Script... 092432.86 2 rv replace start (strlen>500) 092433.04 2 Run Script waiting. iRunWait=1 (shellid=1116, process=1540) 092434.16 2 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE 092434.16 2 task completed (shellid=1116, process=1540) vgm=112, iRunWait=1, iRunWait_ExeResult_NextVgm=0 092434.18 2 no result file returned from program (VGRUNRESULT_2.TXT or SHLRESLT.TXT) 092434.19 2 init atidle reinit : start 092434.19 2 state Waiting for a call... By the way, we found too many problems after we installed VG 4 Dialogic patch, is it not stable enough to be on the production line? Jack Share this post Link to post
SupportTeam Report post Posted 07/05/2005 11:07 PM Mesage stopped playing as the busy tone was heard. You can see this in the trace on this line: 092431.22 2 LsPlayMsg EV_UNKNOWN_134,BUSY How have you setup the busy tone in ConfigLine.xml and does it match closely to what the actual busy tone on these lines is? What problems have you experienced with "VoiceGuide for Dialogic"? Where the problems perhaps caused by card detecting busy tone (as above) or was it something else? There are no stability issues with "VG for Dialogic" while it is running (some sites get an error message upon exit - we're looking it this now). Share this post Link to post
Guest Jack_VR Report post Posted 07/06/2005 07:19 PM Hi, What happened was that I was cut off while I was listening to the message and the system gave out the log file, i didn't hear anything like busy tone on my phone, anything else could be? I didn't change the busy tone setting in configline.xml. I've posted some topics here about VG 4 Dialogic, you can search the topics posted by Jack_VR in the past a couple of weeks. As I said before, the system was working good before we installed VG 4 Dialogic patch. Jack Share this post Link to post
SupportTeam Report post Posted 07/06/2005 10:29 PM What happened was that I was cut off while I was listening to the message and the system gave out the log file, Yes. Message stopped playing as the Dialogic card reported that the busy tone was heard. You should change the ConfigLine.xml file settings to match the tones played on the phone lines which you are using. To find out the frequencies of the disconnect tone just record it using VoiceGuide's Record module (just start recording then hang up) and then analyze the frequencies using any of the more advanced sound editors eg: Audacity (http://audacity.sourceforge.net/) has a View->Plot Spectrum menu. If trying to detect a continuous tone which does not have ON/OFF cadence you should set the "Repetition Count" to be 0. There have been a few good threads covering this on VoiceGuide's Support Forum: http://voiceguide.com/forums/index.php?showtopic=599 http://voiceguide.com/forums/index.php?showtopic=768 In 'VG for Dialogic' the tones are set using the ConfigLine.xml file, not using Dialogic TSP. Share this post Link to post
