Unexpected Routing In Script
I have designed a simple script (is there anyway of uploading the script?) but am experiencing problems with unexpected routing issues when a call is received. Two issues have been found so far, but I expect these are related to a common reason. - This could be my inexperience with voiceguide.
Script is basically:
welcome_message (play file)
Paths:on {timeout 0} goto [main_menu]
main_menu (play file)
Paths:on {1} goto [enter_your_number]
on {2} goto [how it works]
on {3} goto [what_next]
how_it_works
Paths:on {timeout 1} goto [main_menu]
on {9} goto [main_menu]
What happens:
When a call is answered the welcome message is played, this is immediately followed by the main_menu element which takes a keypad input and correctly transfers execution to:
on 1 enter_your_number
on 2 how_it_works
on 3 what_next
All of these execute correctly, however if 2 is selected, the script how_it_works plays the appropriate sound file but at the end, fails to return to the main_menu module.
Paths in how_it_works module are:
The on{timeout 1} gogo [main_menu] does not appear to function, after some time, the how_it_works message replays. Keying 9 does however return you to the main_menu module.
The log below show call handling, once the call is hung up by the caller, the system continues for a number of minutes after the call is cancelled, ie another problem is that the system is not detecting the line being dropped (Dialogic D/4PCI)
The other script problem similar to that above is in the module emerg_intro, this is suppoed to pass execution to the next module emergency_menu when the sound file has been played. The paths are defined as follows:
on {timeout 0} goto [emergency_menu]
However, this pass does not happen either and after a time (default timeout?) the emerg_intro is replayed.
Below is a log of a call showing handling of 1st problem. (some of the sound files are up to a minute in length, is this likely to be an issue?).
141050.17 6 linedevstate 2048 0 0
141050.17 6 callstate OFFERING 66459 0 4
141050.17 6 callinfo CALLEDID
141050.19 6 callinfo ORIGIN
141050.19 6 ring 0
141056.17 6 ring 2
141056.17 6 Answer the call at 02/10/2003 14:10:56
141056.17 6 lineAnswer(66459) => 66493
141056.72 6 callstate CONNECTED 66459,1,0
141056.72 6 WorkingModeTAPI=
141056.72 6 WorkingModeScript=
141056.75 6 Inband detection not enabled
141056.75 6 StartLoadedVgs at 02/10/2003 14:10:56
141056.75 6 tapi Reply 66493 0
141056.75 6 [welcome_message] Playing
141056.75 6 [welcome_message] Playing (C:\IVR Dev\wav files\script01\welcome_message.wav)
141056.77 6 PlaySoundStart ok [C:\IVR Dev\wav files\script01\welcome_message.wav]
141056.78 6 RunModule PLAY end
141201.80 6 wb(87039000)
141202.81 6 Play End line[6] (id=870390)
141202.81 6 LsPlayMsg EV_PLAY_FINISHED
141202.81 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
141202.81 6 [main_menu] Playing
141202.81 6 [main_menu] Playing (C:\IVR Dev\wav files\script01\main_menu.wav)
141202.83 6 PlaySoundStart ok [C:\IVR Dev\wav files\script01\main_menu.wav]
141202.83 6 RunModule PLAY end
141218.75 6 wb(93645300)
141219.77 6 dtmf 2 (50,2)
141219.77 6 LsPlayMsg 2
141219.78 6 PlaySoundStop ok
141219.78 6 Play End line[6] (id=936453)
141219.78 6 [how it works] Playing
141219.78 6 [how it works] Playing (C:\IVR Dev\wav files\script01\how_it_works.wav)
141219.80 6 PlaySoundStart ok [C:\IVR Dev\wav files\script01\how_it_works.wav]
141219.81 6 RunModule PLAY end
141344.11 6 wb(95342100)
141345.13 6 Play End line[6] (id=953421)
141345.13 6 LsPlayMsg EV_PLAY_FINISHED
141350.48 6 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
141350.48 6 [how it works] Playing (C:\IVR Dev\wav files\script01\how_it_works.wav)
141350.50 6 PlaySoundStart ok [C:\IVR Dev\wav files\script01\how_it_works.wav]
141354.86 6 dtmf 9 (57,2)
141354.86 6 LsPlayMsg 9
141355.88 6 PlaySoundStop ok
141355.88 6 [main_menu] Playing
141355.88 6 [main_menu] Playing (C:\IVR Dev\wav files\script01\main_menu.wav)
141355.89 6 PlaySoundStart ok [C:\IVR Dev\wav files\script01\main_menu.wav]
141355.89 6 RunModule PLAY end
141411.80 6 wb(4951500)
141412.81 6 Play End line[6] (id=49515)
141412.81 6 LsPlayMsg EV_PLAY_FINISHED
141414.89 6 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
141414.89 6 [main_menu] Playing (C:\IVR Dev\wav files\script01\main_menu.wav)
141414.91 6 PlaySoundStart ok [C:\IVR Dev\wav files\script01\main_menu.wav]
141430.77 6 wb(6853100)
141431.78 6 Play End line[6] (id=68531)
141431.78 6 LsPlayMsg EV_PLAY_FINISHED
141433.86 6 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
141433.86 6 [main_menu] Playing (C:\IVR Dev\wav files\script01\main_menu.wav)
141433.88 6 PlaySoundStart ok [C:\IVR Dev\wav files\script01\main_menu.wav]
141449.77 6 wb(8750000)
141450.78 6 Play End line[6] (id=87500)
141450.80 6 LsPlayMsg EV_PLAY_FINISHED
141501.63 6 LsPlayMsgFinished EV_TIMEOUT_HANGUP
141501.63 6 Hanging up call...
141501.63 6 RecSoundStop ok
141501.63 6 PlaySoundStop ok
141501.63 6 fnHangupCall end
141501.66 6 linedevstate 2048 0 0
141501.66 6 callstate IDLE 66459 0 0
141501.66 6 WorkingMode@Idle=
141501.67 6 tapi Reply 66476 0
141502.72 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
141502.72 6 ReinitTelephony due to IDLE start
141502.72 6 tapic lineDeallocateCall(MainCall:66459) 0
141502.86 6 lineOpen(6) => 0
141502.86 6 Waiting for a call...
141502.86 6 lineOpen(6)LineHandle=66323
The timout starts after the last replay of the main message in module - what is the "Replay" value set to in that module?
Plese read thread: http://voiceguide.com/forums/index.php?showtopic=599
some of the sound files are up to a minute in length, is this likely to be an issue?.
No. Any length sound files can be used.
