Dialogic Drops Line At Beginning Of Script
This appears to be a similar problem to 879, On my own script the line is dropped after 3 or so seconds, trying the credit card script the line is dropped almost immediately:
002523.45 5 linedevstate 2048 0 0
002523.45 5 callstate OFFERING 65862 0 4
002523.45 5 Answer the call at 03/12/2003 00:25:23
002523.47 5 lineAnswer(65862) => 66135
002523.47 5 callinfo CALLEDID
002523.47 5 callinfo ORIGIN
002523.47 5 ring 0
002524.02 5 callstate CONNECTED 65862,1,0
002524.02 5 WorkingModeTAPI@Connected=
002524.02 5 WorkingModeScript@Connected=
002524.05 5 Inband detection not enabled
002524.05 5 StartLoadedVgs at 03/12/2003 00:25:24
002524.05 5 tapi Reply (LineEvReply) ok 66135 0
002524.05 5 [Get Client ID] Number Input
002524.05 5 [Get Client ID] Playing (PayGetId.wav)
002524.13 5 PlaySoundStart ok [PayGetId.wav]
002524.69 5 callstate DISCONNECTED 65862,0,0
002524.69 5 LsGetNbrsPlayWelcMsg EV_REMOTEPARTY_DISCONNECT
002524.69 5 Hanging up call...
002524.69 5 RecSoundStop ok
002524.75 5 PlaySoundStop ok
002524.75 5 fnHangupCall end
002526.05 5 linedevstate 2048 0 0
002526.05 5 callstate IDLE 65862 0 0
002526.05 5 WorkingMode@Idle=
002526.06 5 tapi Reply (LineEvReply) ok 66118 0
002527.08 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
002527.08 5 ReinitTelephony due to IDLE start
002527.08 5 tapic lineDeallocateCall(MainCall:65862) 0
002527.22 5 lineOpen(5) => 0
002527.22 5 Waiting for a call...
002527.22 5 lineOpen(5)LineHandle=65947
002608.22 0 sys cleanup Start
002608.22 0 sys cleanup End
This is using Dialogic D4/PCI and version 5.1.3a
Call disconnect tones set as per your last advice
Is this a problem with 5.1.3a?
Trace show that it is the Dialogic card that has informed VG that the call is DISCONNECTED.
This looks like the card is mistakenly detecting sound on the line as a disconnect tone...
Does this still happen when you try playing a different sound file?
Can you try disabling the disconnect tone detection on the card by setting all the tone frequencies to 0 on the Dialogic TSP (for both disconnect tones) and see if this makes any difference..
Further information on this, the same line drop occurs even when the dialogic card is set not to listen for a line drop tone.
004848.06 5 linedevstate 2048 0 0
004848.06 5 callstate OFFERING 66187 0 4
004848.06 5 Answer the call at 03/12/2003 00:48:48
004848.08 5 lineAnswer(66187) => 66051
004848.08 5 callinfo CALLEDID
004848.08 5 callinfo ORIGIN
004848.08 5 ring 0
004848.61 5 callstate CONNECTED 66187,1,0
004848.61 5 WorkingModeTAPI@Connected=
004848.61 5 WorkingModeScript@Connected=
004848.66 5 Inband detection not enabled
004848.66 5 StartLoadedVgs at 03/12/2003 00:48:48
004848.66 5 tapi Reply (LineEvReply) ok 66051 0
004848.66 5 [welcome_message] Playing
004848.66 5 [welcome_message] Playing (C:\11Khz Lois\new prompts\Call Intro.wav)
004848.72 5 PlaySoundStart ok [C:\11Khz Lois\new prompts\Call Intro.wav]
004848.72 5 RunModule PLAY end
004851.83 5 callstate DISCONNECTED 66187,0,0
004851.83 5 LsPlayMsg EV_REMOTEPARTY_DISCONNECT
004851.83 5 Hanging up call...
004851.83 5 RecSoundStop ok
004851.88 5 PlaySoundStop ok
004851.88 5 fnHangupCall end
004851.92 5 linedevstate 2048 0 0
004851.92 5 callstate IDLE 66187 0 0
004851.92 5 WorkingMode@Idle=
004851.92 5 tapi Reply (LineEvReply) ok 66153 0
004852.98 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
004852.98 5 ReinitTelephony due to IDLE start
004852.98 5 tapic lineDeallocateCall(MainCall:66187) 0
004853.13 5 lineOpen(5) => 0
004853.13 5 Waiting for a call...
004853.13 5 lineOpen(5)LineHandle=66102
004931.77 0 sys cleanup Start
004931.77 0 sys cleanup End
Our posts crossed, however I have now set the card to listen for disconnect tone and set all tones/times to zero. The result of this is immediate disconnection before any part of the message is played:
005424.42 5 linedevstate 2048 0 0
005424.42 5 callstate OFFERING 65863 0 4
005424.42 5 Answer the call at 03/12/2003 00:54:24
005424.45 5 lineAnswer(65863) => 65982
005424.45 5 callinfo CALLEDID
005424.45 5 callinfo ORIGIN
005424.45 5 ring 0
005424.97 5 callstate CONNECTED 65863,1,0
005424.97 5 WorkingModeTAPI@Connected=
005424.98 5 WorkingModeScript@Connected=
005425.02 5 Inband detection not enabled
005425.02 5 StartLoadedVgs at 03/12/2003 00:54:25
005425.02 5 tapi Reply (LineEvReply) ok 65982 0
005425.02 5 [welcome_message] Playing
005425.02 5 [welcome_message] Playing (C:\11Khz Lois\new prompts\Call Intro.wav)
005425.08 5 PlaySoundStart ok [C:\11Khz Lois\new prompts\Call Intro.wav]
005425.08 5 RunModule PLAY end
005425.30 5 callstate DISCONNECTED 65863,0,0
005425.30 5 LsPlayMsg EV_REMOTEPARTY_DISCONNECT
005425.30 5 Hanging up call...
005425.30 5 RecSoundStop ok
005425.34 5 PlaySoundStop ok
005425.34 5 fnHangupCall end
005427.02 5 linedevstate 2048 0 0
005427.02 5 callstate IDLE 65863 0 0
005427.02 5 WorkingMode@Idle=
005427.02 5 tapi Reply (LineEvReply) ok 65965 0
005428.03 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
005428.03 5 ReinitTelephony due to IDLE start
005428.03 5 tapic lineDeallocateCall(MainCall:65863) 0
005428.17 5 lineOpen(5) => 0
005428.17 5 Waiting for a call...
005428.19 5 lineOpen(5)LineHandle=65692
Further experiments should this is associated with the frequencies set for detecting a disconnect tone. In the UK this frequency is 400Hz as soon as the disc tone is set to 400 with a deviation of any more than about 15, the call drops within 10 - 15 seconds. At the deviation value is increased the call can be made to drop almost immediately.
Sadly, setting the freq deviation below about 15 means that the call is not dropped when the called actually does drop the line.
All of this was carried out using the demo credit card script.
Is the forthcoming dialogic version of VG likely to help in this, at present this makes the system largely unusable as my script is designed such that timeouts return back to a main menu (this is scripted into the voice prompts I have had recorded, so reprogramming the script to drop the line on no input or timeout would contradict what the caller is being told.
Although I have only intermittently got it working, loop current drop would seem to be the way forward here, or am I right in assuming this is still disabled in 5.1.4
This almost looks like the card is faulty... setting it to 0 should have disabled the disconnect tone detection... lets try another way of disabling disconnect tone detection:
Can you try setting the Disconnect tones to be something like 1000Hz with 0Hz deviation, and setting the cadence really long - like 5 seconds on & off, and specify a high number of repetitions - like 5 or 10...
After changing the settings please restart the PC to make sure the new settings take hold...
considering the other strange problem that you are having with this card (http://voiceguide.com/forums/index.php?showtopic=881) I would not be surprised if the card is faulty...
OK Tried as you have suggested and there are no line drops at all, but then there are no drops when the card is set to default frequencies. This problem is only occuring when I use a single continuous frequency of 400Hz which is the line disconnect tone frequency.
I know I have experienced problems before, and those too were attributable to settings around the disconnect tone frequencies. I am not convinced on the hardware fault now since everything else is working OK and the diagnostics show no problem.
1. By way of a work around is it possible to get a script to timeout after say 5 minutes total line time?
Thanks for your suggestions, could you also answer the following points:
2. Does v5.1.4 support loop disconnect?
3. Will the forthcoming dialogic version improve on the disconnect
4. Do you know of any other UK users using D/4PCI and BT lines who have overcome the caller disconnects problem?
Yes. You can use the $RV_CALLLENGTH variable during the script to test for call length.
No. this has been temporarily disabled while we look for a solution to a bug this is causing.
It's the Dialogic card which is reporting the disconnect tone - and the settings which you are using right now to configure the Dialogic card are the only settings for configuring the Dialogic card's disconnect tone detection.
Apart from frequency settings how have you set to cadence timings & repetitions? they also need to be set right to ensure that you do not get 'false-positives'.
The cadence should be set to within 10% margins and the repetitions should be set to 3 or higher...
Can you post a screenshot of your current settings or do a 'save-as-text' of your settings and post them here.
We're not aware of anybody else reporting issues with getting a Dialogic card to detect disconnect tones properly...
there are some related posts on this forum already:
http://voiceguide.com/forums/index.php?showtopic=768
http://voiceguide.com/forums/index.php?showtopic=599
Thanks for the response, attached is a new recording of the disconnect tone, this appears to have a silent delay from the click of the phone being disconnected this silence is then followed by 6 seconds at 400Hz.
I am unable until later (when the lines stop) to alter the frequencies, currently they are set as per the attached file (in zip) however these settings are the test ones you suggested, with them (as expected) there is no line drop either when required or by accident.
I have used the settings recommended by you from the last disconnect tone sent, but these seem to drop the line on a false positive basis. I have this connected to three lines and the problem exists on all three.
Later tonight I will be able to change the frequencies back and experiment again.
disconnect.zip
Sounds like you should set a cadence to 6 seconds on, then a few seconds off...
If the tone is sent only once then you should set the 'repetitions' count to 1...
I have tried various parameters based around a 6 second on time for the 400Hz but none of these result in a dropped line being detected. I have no previous experience in being able to interpret the tone recorded and the setting of parameters on the dialogic card. I sent a copy of the disconnect tone earlier in this thread. Attached to this message are the current board settings. I would be very grateful if you could recommend settings based on your experience and the previous tone file.
d41cfg_6sec.txt
looking at your current seting:
  Page = Tone parameters dialog (disconnect tone ID = 7)
  Effective configuration = Default
_______________________________________________________________________
Parameter  Default value Custom value
Frequency 1              620    400
Frequency 2              480      0
Frequency 1 deviation      10    200
Frequency 2 deviation    200      0
On time                  600      30
Off time                  20      20
On time deviation          10      10
Off time deviation        10      10
  Page = Tone parameters dialog (disconnect tone ID = 8)
Frequency 1              550    400
Frequency 2                0      0
Frequency 1 deviation      20    200
Frequency 2 deviation      0      0
On time                  300      30
Off time                  20      0
Off time deviation        10      0
  Page = Tone parameters dialog (disconnect tone ID = 11)
Frequency 1              1100    1100
Frequency 2                0      0
Frequency 1 deviation      40      40
On time                    50      50
Off time                  300    300
It looks like you have most settings set to 'Default' - insetad of slsecting 'Custom' and changing them to what you want...
From what you describe I'd aim to have each 'disconnect' and 'busy' tone entry set to:
  Effective configuration = Custom
Frequency 1              620    400
Frequency 2              480      0
Frequency 1 deviation      10      30
On time                  600    600
Off time                  20    200
On time deviation          10    100
Off time deviation        10    100
I have now amended the setup as suggested, but the effect of this is to prevent voiceguide from starting. If after the pc is booted (and 60seconds delay) I run VG Config, set a script on the three lines in use and click the start checkbox, VG fails to start, sometimes the VG window will open but no lines appear int he line device/state table. Task manager reports that VG is not responding and I have to reboot.
If I set the second disc tone to default rather than the same custom values, the card / voiceguide work, but again the disconnect tone is not detected properly and no hand up is effected.
Attached is config file to show setup. I will post another message starting a new thread requesting details of anyone using a D/4PCI on BT lines in the UK
d41cfgnew.txt
Changing the disconnect tone detection settings of the Dialogic card should not affect VG in any way... is the Dialogic service starting OK?
if the problem lies with the Dialogic service then you may need to experiment more with what settings are causing these problems on your system....
