Line Dropout
Hi have have a problem that the line is dropping after jas a few seconds midway thru playing a wav file
this is the log, attached is the wav that is being played
150654.80 9 linedevstate 2048 0 0
150654.81 9 callstate OFFERING 66549 0 4
150654.81 9 callinfo CALLEDID
150654.82 9 callinfo ORIGIN
150654.82 9 ring 0
150654.82 9 Could not obtain handle to kill process. (new call) 1268, 0
150654.82 9 Answer the call at 3/12/2003 3:06:54 PM
150654.82 9 lineAnswer(66549) => 65832
150655.35 9 callstate CONNECTED 66549,1,0
150655.36 9 WorkingModeTAPI@Connected=
150655.36 9 WorkingModeScript@Connected=
150655.37 9 Inband detection not enabled
150655.37 9 StartLoadedVgs at 3/12/2003 3:06:55 PM
150655.38 9 tapi Reply (LineEvReply) ok 65832 0
150655.38 9 [get_propid] Number Input
150655.38 9 [get_propid] Playing (officeid.wav)
150655.39 9 PlaySoundStart ok [C:\vgscript\officeid.wav]
150656.63 0 sys cleanup Start
150656.63 0 sys cleanup End
150658.07 9 callstate DISCONNECTED 66549,0,0
150658.08 9 LsGetNbrsPlayWelcMsg EV_REMOTEPARTY_DISCONNECT
150658.08 9 Hanging up call...
150658.08 9 RecSoundStop ok
150658.14 9 PlaySoundStop ok
150658.14 9 fnHangupCall end
150658.17 9 linedevstate 2048 0 0
150658.17 9 callstate IDLE 66549 0 0
150658.18 9 WorkingMode@Idle=
150658.18 9 After Hangup script:[C:\vgscript\ftp.vgs]
150658.18 0 LoadedVgs_Find C:\vgscript\ftp.vgs at idx=2
150658.18 9 [ftp file] Run Program
150658.19 9 RVreplace start (strlen>100)
150658.20 9 On Success path not defined.
150658.20 9 Hanging up call... [Run module 2392]
150658.20 9 HangupCall_Common Mode=AfterHangupRun
150658.20 9 ReinitTelephony due to IDLE start
150658.20 9 tapi Reply (LineEvReply) ok 65986 0
150658.24 9 tapic lineDeallocateCall(MainCall:66549) 0
150658.40 9 lineOpen(9) => 0
150658.40 9 Waiting for a call...
150658.40 9 lineOpen(9)LineHandle=66173
officeid.zip
