NOTE: Deprecated. Please use Trace function instead.
Adds a log entry to VoiceGuide's vgEngine trace log.
object.Admin_TraceLogAdd iLineId, iLogLevel, sLogInfo
object | Required. VoiceGuide object |
iLineId | Required. Identification number of the line with which this log entry is associated. Set to 0 if not used. |
iLogLevel | Required. Compared against VoiceGuide's trace level setting to determine if the log entry should be printed. Set to 0 for the trace log entry to be always printed. |
sLogInfo | Required. the information to be printed |
VoiceGuide's trace level is set using VG.INI file, section "TraceLog", entry "TraceLevel"
vg.Admin_TraceLogAdd 0, 0, "This trace was printed from an external VB Script"
