Adds a new entry to Dialer's OutDialQue database. The call will be made as outgoing lines become available, and the time before the call is made may depend on how many other entries are currently loaded in the OutDialQue database. No return information about when the call will be actually made is provided when this function returns.
If no other entries are in the OutDialQue database and there are outgoing lines available then the call will be made immediately.
Syntax:
object.Dialer_OutDialQueAdd sPhoneNumber,
sPhoneNumberPrefix, sActivateTime,
sDayTimeStart, sDayTimeStop,
sDaysCallAllowed, sLineSelection,
sCampaignName, iPriority, sOnAnswerLive, sOnAnswerMachine, sFaxToSend, sOnNotAnswered, sOnRetriesExhausted, iAnswerTimeout,
iRetriesLeft, iRetriesDelay,
sRV, sCallOptions, sEscalationCalls
object VoiceGuide object sPhoneNumber Thetelephone number to be called sPhoneNumberPrefix Optional prefix dialed before the telephone number. ActivateTime Date and Time when the call should be made.
In v7 the time can be specified as a string in any locally valid date/time format.
This format is recognized worldwide: YYYY-MM-DD
HH:NN:SS AM/PM the AM/PM sign can be omitted if using
24-hout time notation. The YMMDDHHNN format can also be used.
In v6 the time can be specified as a number in format YMMDDHHNN.
DayTimeStart Time of
the day before which the call to this number should not be made.
In v7
This format is recognized worldwide: HH:NN:SS AM/PM the AM/PM sign can be omitted if using
24-hout time notation. The HHNN format can also be used.
In v6
the time can be specified as a number in format HHNN. eg: 8am would be specified as the number 800.
To allow this telephone number to be dialed from midnight onwards set to 0
DayTimeStop Time of the day after which the call to this number should not be made.
In v7 the time can be specified as a string in any locally valid date/time format. This format is recognized worldwide: HH:NN:SS AM/PM the AM/PM sign can be omitted if using 24-hour time notation.
In v6 the time can be specified as a number in format HHNN. eg: 9pm would be specified as the number 2100. To allow this telephone number to be dialed at any time of day set to 0 sDaysCallAllowed Days of the week when the call can be made. Specify each day using the first two
characters of that day eg: to call on weekdays only specify "MoTuWeThFr". If not used (ie: can call on all days) set to empty string
sLineSelection If the outbound call may only be made on particular phone lines then these lines
should be listed in this setting. Line IDs may be specified as a comma
delimited list of "LineIDs" (eg: 6,7,8 ) or
using XML notation, (eg: <LineId>2</LineId><LineId>3</LineId> )
or specified as a comma delimited list of the Dialogic line identifiers (eg:dxxxB1C2,dxxxB1C3 ).
If left blank then any available lines will be used.
sCampaignName Campaign
name associated with this call. Used for users own categorizing of calls. Can
be left as an empty string.
iPriority At what
priority level the calls should be made. A lower number indicates a higher
priority. ie: 1 is the
highest priority, then 2, then 3 ... etc. Number of priority levels is
unlimited.
sOnAnswerLive VoiceGuide
script to run when the call is answered by a real person.
sOnAnswerMachine Sound file (or VoiceGuide script) to be played if the call is answered by an answering machine. The sound file will be played after the answering machine's welcome message finishes. If not used set to empty string "" sFaxToSend .PDF/.TIF/.TIFF file to send, or VoiceGuide script to be started immediately after dialing. If this setting specified then the sOnAnswerLive and sOnAnswerMachine
are effectively ignored, as when sending fax the fax calling tone has to be sent immediately after dialing. If not used set to empty string ""
sOnNotAnswered .EXE/.COM/.BAT or .VBS (VBScript) to run when the call has not been answered. If not used set to empty string "" sOnRetriesExhausted .EXE/.COM/.BAT or .VBS (VBScript) to run when the call has not been answered and there are no more retries left. If not used set to empty string "" iAnswerTimeout How many seconds will the Dialer wait for the call to be answered. Default value of 60 will be used if this entry is set to 0 iCallRetriesLeft How many more times will the Dialer attempt to call this number if the next call is unsuccessful. To only make one call attempt set to 0 iRetriesDelay How many minutes will the Dialer wait before attempting to call again. If not used set to 0 sRV Result Variables which will be available to the VoiceGuide script used on this call. If not used set to empty string "" sCallOptions XML formatted options string. If not used set to empty string "" sEscalationCalls Can be used to specify multiple escalations levels. XML format is used to specify the escalation calls. Please see the VoiceGuide's help file's section on the 'Out Dial' file for details on the
XML format used to specify call details. If not used then set to empty string "".
Version 7 Examples:
Example 1
Straightforward
example.
vg.Dialer_OutDialQueAdd "ext1002@10.1.1.4",
"", "2009-11-28 9:00:00 AM", "9:00 AM", "5:00
PM", "", "", "BookingConfirmCampaign", 1,
"c:\ConfirmBooking.vgs", "c:\CallBackDetails.wav", "",
"c:\ifNotAnswered.vbs", "c:\ifRetriesExhausted.vbs", 90, 2,
30, "[CustomerID]{44563}", "",
