Action
Instructs VoiceGuide to perform the specified Action.
result = object.Action(iLineId, sAction, iParam1, iParam2, iParam3, sParam1, sParam2, sParam3)
result Returned value
object VoiceGuide object
iLineId Identification number of the line with which this function is associated. Set to 0 if not used.
sAction Action to perform.
iParam1 Integer parameter 1
iParam2 Integer parameter 2
iParam3 Integer parameter 3
sParam1 String parameter 1
sParam2 String parameter 2
sParam3 String parameter 3
vg.Action $RV_LINEID, "setchannelstate", 0, 0, 0, "outofservice", "", ""
