Returns control of the call to the calling script.
object.Script_Return iLineId, sRvList
Part |
Description |
object |
VoiceGuide object |
iLineId |
Identification number of the line |
sRvList |
List of Result Variables and their values. Each RV-Value pair is in format [Name]{Value} a number of RV-Value pairs can be specified one after another. |
Effectively pops the return destination script/module of the call stack and start execution at that script/module.
When used in the Run VBScript modules: the jump to next module is made immediately when Script_Return is called, so Script_Return usually should be the last function in the script (before 'set vg = Nothing')
Example 1
vg.Script_Return $RV_LINEID, ""
Example 2
vg.Script_Return $RV_LINEID, "[PersonalDataVerified]{True}"
