Jump to new VoiceGuide script and/or module.
object.Script_Goto iLineId, sDestScript, sDestModule, sRvList
Part
Description
object
VoiceGuide object
iLineId
Identification number of the line
sDestScript
The filename of the VoiceGuide script where the module subscript is located. If the subscript is in the same VoiceGuide script as the calling module then this entry can be left blank.
sDestModule
Name of the starting module. If left blank then the script's default starting module is used.
sRvList
List of Result Variables and their values. Each RV-Value pair is in format [Name]{Value} a number of RV-Value pairs can be specified one after another.
If the module names are blank then the default starting modules in the script are used.
When used in the Run VBScript modules: the jump to next module is made immediately when Script_Goto is called, so Script_Goto usually should be the last function in the script (before 'set vg = Nothing')
vg.Script_Goto $RV_LINEID, "GetPayment.vgs", "", ""
