Answer an incoming call and run VoiceGuide script.
object.Line_Pickup iLineId, sVgScriptToRun
object Required. VoiceGuide object
iLineId Required. Identification number of the line. If set to 0 then the first device controlled by VoiceGuide will answer the call.
sVgScriptToRun   Required. VG Script to run after answering call
There must be an incoming call on the line.
vg.Line_Pickup $RV_LINEID, "C:\Scripts\CallRec\RecCall1.vgs"
