Temporary Files
VoiceGuide v7 will save temporary files in \temp\ subdirectory.
Rec_Am_X.wav files are made during End Of Answering Machine Message detection.
X is the "LineID" of the line making the call.
There should be no more of these "Rec_Am" files then the number of lines on the system
TTS_X_Y.wav files are created during Text To Speech and contain the actual TTS generated sound that was played.
X is the "LineID" of the line and Y is the TTS generation counter during the call.
There should be no more of these "TTS" files then the number of lines on the system * max number of times the TTS is used during the call.
vbs_X_Y.wav files store the VBScript that was ran.
X is the "LineID" of the line and Y is the VBScript module counter during the call.
There should be no more of these "vbs" files then the number of lines on the system * max number of times the VBScript module is used during the call.
These files will only be created if SaveToFile option has been enabled in section [moduleRunScript] in VG.INI
js_X_Y.wav files store the Java Script that was ran.
There should be no more of these "js" files then the number of lines on the system * max number of times the JavaScript module is used during the call.
The older versions of the files are overwritten by newer versions, so there is an upper limit of how many files can be in TEMP directory, and all the TEMP files store data related to last call on system made on that line only.
