Transmits data over a serial port.
object.Serial_Tx iSerialPortNumber, sTx
object | VoiceGuide object |
iSerialPortNumber | Serial port number. |
sTx | String to be sent on the Serial port. |
Default parameters for the serial connection can be set in VG.INI file, using section [Serial]:
[Serial]
CommPort=1
Handshaking=0
InBufferSize=1024
InputMode=1
NullDiscard=False
ParityReplace=?
RThreshold=1
RTSEnable=False
Settings=9600,N,8,1
Calls to
function will then send send the specified data over the Serial port. The Serial
port will be opened during the sending of data and closed immediately
afterwards.
vg.Serial_Tx 1, "This is a test sent from VoiceGuide."
