Returns all the Result Variables current for the specified line in XML-ish format
sResult = object.RvGet_AllXml iLineId
| Part | Description |
| object | VoiceGuide object |
| iLineId | Identification number of the line |
| sResult | Result Variables currently defined for the selected line. Returned on XML-ish format |
The returned data defines each variable in XML format, but no XML headers or footers are supplied.
Result Variables are reset at the beginning of a new call. Hence they are available for querying after the call has finished, but before a new call has begun on the same line.
sReturnValue = vg.RvGet_AllXml($RV_LINEID)
MsgBox sReturnValue
