Returns information from the called Program or script back to VoiceGuide - indicating what path VoiceGuide should take next from the "Run Program" or "Run VBScript" modules.
object.Run_ResultReturn iLineId, sResult
Used to return results if VoiceGuide is currently awaiting results from a called Program or Script.
If a list of $RVs is returned then a Success path will be taken.
When used in the Run VBScript modules: the jump to next module is taken immediately when Run_ResultReturn is called, so Run_ResultReturn usually should be
the last function in the script (before 'set vg = Nothing')
Example 1
CreateObject("vgServices.CommandLink") Example 2
Part
Description
object
VoiceGuide object
iLineId
Identification number of the line
sResult
Result returned to VoiceGuide. Can be "success", "fail", "true",
"false" or a string of Result Variables. If set to empty string then the Fail path will be taken
vg.Run_ResultReturn $RV_LINEID, "[MarketDow]{9,321}[MarketNasdaq]{1,702}[MarketSP500]{990}"
