Start Recording the sound from two sources into the specified file. Can be used to record:
  • Both sides of a bridged/conferenced call, or
  • Caller's interaction with the IVR
  • Can also record each side of the call into separate files. Those separate files can then be used to create a trasncription of the call that identifies what each party said.
    object.Record_2Lines_Start iLineIdRec, iLineId1, iLineId2, sSoundFile, sOptions
    object VoiceGuide object
    iLineIdRec LineID or device name of the line handling the recording process.
    iLineId1 LineID or device name of the first line to be recorded
    iLineId2 Identification number of the second line to be recorded
    sSoundFile Filename of the created sound file
    sOptions Options
    Options
    play_beep : Play a beep tone when recording
    ab_split : Make separate 'A' side and 'B' side recordings as well as the main recording.
    Note:
    In the examples below the predefined vgo object is used, instead of creating the "vgServices.CommandLink" object.
    Example : Record a bridged call between two parties.
    vgo.Record_2Lines_Start $RV_LINEID, $RV_LINEID, $RV[Conf_LineId_2], "c:\recfile.wav", ""
    Example : Record caller's interaction with the IVR. Everything caller says/presses and everything the IVR plays will be recorded.
    A "Pool" of voice resources must be set up in order to use this functionality. One "Pool" voice resource is used for this call.
    vgo.Record_2Lines_Start $RV_LINEID, $RV_LINEID, $RV_LINEID,, "c:\recfile.wav", ""
    Example : Record a bridged call into the 3 separate files: Main, A-Side, B-Side.
    A "Pool" of voice resources must be set up in order to use this functionality. Two "Pool" voice resource are used for this call.
    vgo.Record_2Lines_Start $RV_LINEID, $RV_LINEID, $RV[Conf_LineId_2], "c:\newfile.wav", "ab_split"
    Note : To create a "Pool" of voice resources the <Pools> section would need to be placed inside the node of the Config.xml file.
    Voice devices then must be allocated to the pool. Voice devices allocated to the pool cannot be assigned to any line/channel.
    <Pools>
     <Pool_Voice>
      <Device_Voice>dxxxB11C1</Device_Voice>
      <Device_Voice>dxxxB11C2</Device_Voice>
      <Device_Voice>dxxxB11C3</Device_Voice>
      <Device_Voice>dxxxB11C4</Device_Voice>
      <Device_Voice>dxxxB12C1</Device_Voice>
      <Device_Voice>dxxxB12C2</Device_Voice>
      <Device_Voice>dxxxB12C3</Device_Voice>
      <Device_Voice>dxxxB12C4</Device_Voice>
     </Pool_Voice>
    </Pools>
